04-16-2018
05:44 AM
- last edited on
03-06-2024
08:59 PM
by
ROGBot
04-28-2018 03:15 PM
05-24-2018 06:19 PM
Wobbler wrote:
Where is the DVD drive connected? I have no such issues with my Blu-Ray drive connected to the 6th SATA port, with 4 HDD and 1 SSD in the others, with 2 M.2 NVMe drives in RAID 0.
Are you using the SATA raid instead of ACHI or just NVMe raid? What AMD raid drivers are you using?
and if you mean "Storage Spaces", that wont require sata raid in bios, since it's software based.
07-22-2018 07:32 AM
07-22-2018 09:41 AM
FlyingBear wrote:
I have a similar issue on my Zenith Extreme: 2x1TB 970 Pro RAID 0 as boot drive. 2TB 970 Evo as the third NVMe drive. When SATA RAID is turned on, the 4TB 960 EVO in SATA 1 disappears. It reappears in AHCI mode.
I only have 3 SATA drives (2x4TB 960 Evo plus Blu-Ray) so I have an easy workaround: not using SATA 1. Hopefully a BIOS fix. I’m on 1003.
07-22-2018 02:02 PM
FlyingBear wrote:
I should add a little more information: the single 2TB 970 Evo has to be a "legacy non-RAID" array under RaidExpert2 to show up in Windows, i.e. it can't be a standalone drive, and hence can't use the Samsung NVMe driver or Samsung Magician, despite not being part of a RAID array. If you delete the "array" (which it isn't), the drive vanishes from Windows. A bummer.
The BluRay drive shows up just fine as a SCSI device in Device Manager and Windows. RAIDExpert2 can't see it.
On the good news side, the 970 Pro array benchmarks in ATTO (current version) at ~5GB/s write and read. The sole 970 Evo sits at ~2.4GB/s, and the 860 Evo array at ~1GB/s. Not bad.
07-22-2018 02:30 PM
Wobbler wrote:
Actually you most likely can use Samsung driver for the single nvme drive, and you probably can delete the "legacy non-RAID", you will need to manually replace the amd bottom device driver(in storage controllers) that the single NVMe drive is using with the samsung driver (1 of the 3). The Samsung software won't work. There is a post by me of this issue, with sort of a workaround +amd driver install issue, with a PCIe slot NVMe drive getting somehow gripped in to the NVMe raid thingie. Access latencies do suffer with the amd bottom device drivers and the NVMe raid layer being in effect.
07-25-2018 06:20 AM
07-25-2018 07:55 PM
Anton Unknown wrote:
After change SATA-mode from AHCI to RAID, all SATA-devices disappears from SATA-device list and boot devices. In my case, RAID-setup for Windows say that NVMe is bootable, therefore it cannot continiue. Manual installation of drivers and RAID Xpert utility make devices available, but cannot create RAID array.
It turned out that for activation of RAID-utility in BIOS option "Boot from Storage Devices" in Boot -> Boot\CSM (Compatibity Support Module) should be changed to "UEFI driver first". By default it set on "Legacy only", that is wrong for UEFI driver and utility for RAID controller.
07-26-2018 03:01 AM
