I noticed that the Zenith Extreme has a ROG_EXT connection. Its manual says
"This connector is for the OC Panel I/II". Now this leaves me hanging because I like dthe
ROG Front Base more than the
OC Panel II, but the manual says nothing about it. Which is weird since both extensions use the same ROG_EXT connection.
When looking at the pages of both extensions, neither list the Zenith extreme as a compatible motherboard, but this may be because ASUS forgot to update them?
Can anyone shed some light on this?
Thank you in advance,
CX
