10-05-2017 03:35 AM
10-06-2017 05:01 AM
10-06-2017 12:29 PM
Wobbler wrote:
Is it normal for USB-C solder joints(2) back of the MB to be just lightly touching, as they are in symmetry I gather is might be but looks suspicious being so thin/small connection.
10-06-2017 04:12 PM
10-06-2017 04:16 PM
Korth wrote:
USB-C connector pinout here. It's okay to bridge the V+ pins (red A4-B9 and A9-B4) and to bridge the GND pins (green A1-B12 and A12-B1). In fact, the pins are mounted to a common electrical substrate, they're already soldered together underneath. Visible solder bridges on the topside won't open/short any electrical paths unless they bridge other adjacent pins, they just look sloppy.
10-06-2017 08:01 PM
10-07-2017 03:28 AM
10-07-2017 04:33 AM
10-10-2017 02:38 PM
