Putting together the wifi antennas
dodgethis_sg
Does anyone know how to put the antenna and the base together? I can't find any instructions on how to do so.
Thanks!
11 REPLIES 11
Bill
Hello dodgethis_sg
Are you asking about the following ?
66995
dodgethis_sg
Nope, that's not it. I need to know how to put the antenna and base together as they come separated from each other.
dodgethis_sg wrote:
Nope, that's not it...
Post a picture of what you have in hand.
Davemon50
dodgethis_sg
here's what I got in the box. As you can see, the antenna is not attached to the base in anyway. I've tried to slide the antenna in but it's too large.
davemon50
Level 11
Well I don't have one but it looks like a simple slip-fit to me. Push harder?
Davemon50
dodgethis_sg
I have already exhausted that avenue, which is why I am asking for help on this forum.
haihane
looks like, from the picture, you take the antenna unit and stab it right through the base hole, then it should snap in place?
i dunno, i'm thinking of this like playing lego
no siggy, saw stuff that made me sad.
dodgethis_sg
It would work, if the antenna doesn't taper into a size larger than the hole in the base.
You put the wire through the hole and insert the antenna from the top.
The antenna is held in place when you put the wire into the tabs that holds it (cable canal).
