10-27-2017
01:57 PM
- last edited on
03-06-2024
08:36 PM
by
ROGBot
10-27-2017 04:34 PM
capitaltpt wrote:
I seem to have an issue with the onboard OLED not working and not being able to control addressable strips in AURA.
OLED - Does not come on at all.
capitaltpt wrote:
shouldn't these be individually addressable like the backplate and RAM LEDs? Any ideas how to get these to work?
10-27-2017 10:31 PM
caknuckles wrote:
Remove the shroud and make sure the OLED is plugged in properly and securely to MB. Mine does not work either and that is what I need to check, but not pulling apart my water loop to do it till maintenance time.
If it fixes it or you find another fix let me know please.
10-28-2017 01:46 AM
10-28-2017 10:36 AM
capitaltpt wrote:
I should mention it did work initially
10-28-2017 01:20 PM
10-28-2017 07:10 PM
Cory29 wrote:
I had a programming friend look into it. He couldn't fix it but said that wiping windows should fix it. I guess the way aura needs to talk to the board is really hacky and leaves junk registry files everywhere that corrupt (the program) on the next board or install - the cleaner that is on the software forum doesn't do its job. So basically unless you have a fresh install of windows every-time you update there is a chance it won't work
10-28-2017 10:02 PM
10-29-2017 01:45 PM
11-04-2017 02:44 AM
