NVMe SSD doesn't show up!
moathsonbol
I have 2 Samsung 960 pro 512 GB NVMe SSDs.
I installed windows on one of them, and i wanted the other to be as a normal storage drive.
But i can't see or access it inside windows (although i can see the drive in Disk Management)
How can i use it as a normal storage drive?
Ljugtomten
You need to format it in Disk Management and assign a drive letter to it.
When i Right-Click on the drive through "Disk Management", all the options are not available.
But i got another idea! 😉
I have a bootable USB with windows 10 on it, so i booted from it and made a new partition from this NVME drive.
Then went back to "Disk Management" in windows, and changed the letter. IT WORKED 😄
Anyway, thanks for your help..
