noob - Zenith Extreme M.2 installation
eco_bach
Hi
Having a difficult time with something that should be so simple. Trying to install a M.2 drive in my new Zenith Extreme mobo but to do so I have to first unscrew 3 tiny Phillips screws on the cover (see attached).
The problem is that they are screwed EXTREMELY tight! I am literally losing skin on my fingers trying to loosen!
And yes I am turning counter clockwise!!
I am using tiny jeweller's screwdriver so the issue may be I simple can't generate enough torque to loosen.
Can anyone tell me which EXACT screwdriver I should be using?
Dimitrios1971
Level 12
for example...
69637
OLD
NEW
