12-21-2017
04:44 AM
- last edited on
03-06-2024
08:43 PM
by
ROGBot
12-29-2017 06:22 AM
12-29-2017 06:26 AM
12-29-2017 12:43 PM
12-31-2017 11:38 PM
Dimitrios1971 wrote:Thanks I got it to work 🙂 though the three drivers you said to add didn't work in the order u said to least for me it wasnt right 🙂 the raid driver had to go first 🙂 anyway bootable raid up and running great thanks for the info
How to Set Up RAID on Your Asus Zenith Extreme & AMD Ryze Threadripper (nvme, SSD, HDD)
NVMe and SSD drive RAID installation AMD Ryzen Thread Ripper on ASUS Zenith Extreme With BIOS version 0801 or bios version 0902
Know that just as windows needs to be rebooted after changing certain settings, so does your BIOS.
Start the computer with F2
Launch CSM: Enabled
Boot Device Control: UEFI Only
Boot from Network Devices: UEFI Driver First*
Boot from Storage Devices: UEFI Driver First*
Boot from PCI-E Expansion Devices: UEFI Driver First*
In the advanced tab do NOT set SATA to RAID. Leave it ACHI
In the advanced tab find the AMD PBS setting and change it to RAID
In the advanced tab you should see the RAIDXpert Raid Configuration option now.
I can't give you exact steps for this, but you may need to delete any arrays, and Please do not initialize the physical disks to create the array....create the array to Both modus...Once you have created your array, move to the next step.
Reboot
Boot from windows USB and begin installation.
On the installation screen where you choose your boot drive, you won't see the array yet. Click on Load Drivers and navigate to your drivers USB to raid-windows-driver-9_01_00_018/ WTx64 (http://www.mediafire.com/file/a2dln7..._01_00_018.zip). You will have to load 3 drivers You have 3 folders and you want to load 3 drivers
Go to first folder RCBottom and install rcbottom.inf
go to the second folder RCConfig and install rcraid.infto
(you should see now you will see 2 big and 2 small ones Partition a Hard Drive in screen ..or 3 if in system 3 have NVMe.... do not be afraid)
the third RCConfig and install rcnfg
Now you should see the raid array. Install windows on the array.
Once Windows has booted, Windows loads now. Please install only the drivers that I have loaded here. Be careful when installing other chipset or RAID drivers
Well, before I forget, please do not install the Samsung NVMe Driver if you're ferich ... otherwise have a bluescrenn after restar
And another thing, Raid to create after this video (https://youtu.be/csiqG_rkSWI) you can forget ...for bios bootable raid
Please install only these driver and only this utility
http://www.mediafire.com/?7rnh3rgo4o3l9
tell me if it is good
Good luck!:cool:
12-30-2017 05:24 AM
jacklolita wrote:
Hi !!!
Im tired trying install samsung 960 pro into a asus zenith extreme.
Someone with the same Mobo and a samsung nvme (or another) , can tell me if in the bios / advanced / onboard devices configuration , appears the nvme ?? conected in M.2_1 or into Dimm.2_m.2_1 or into dimm.2_m2_2 ??
If the nvme appears in the bios , how you install it ? or what bios you used?
i try a lot of configurations and bios, and never see the nvme in the bios, only recognized in boot section, but in the ezmode sata information, never apperars. It say M.2_1 N/A
Dimm.2_m.2_1 N/A
dimm.2_m2_2 N/A
and no options nvme configurations appear into the advanced mode.
Someone can help me please. I only need if someone see the nvme into de bios ezmode sata info or into onboard devices...and if you can see them, tell my the bios you are using, and how you install it. thanks a lot.
i dont know if the mobo is broken , or is a bios problem. I try to conect in another m2 slots, (dimm2 , m2_1...) and not appear. I used another nvme and never appears.
i tried it with 2 different samsung 960 pro and nothin change.
In my bios i only see that;
thanks a lot.
02-18-2019 09:13 AM
