How to Set Up RAID on Your Asus Zenith Extreme & AMD Ryze Threadripper (nvme, SSD, HDD)NVMe and SSD drive RAID installation AMD Ryzen Thread Ripper on ASUS Zenith Extreme With BIOS version 0801 or bios version 0902
Know that just as windows needs to be rebooted after changing certain settings, so does your BIOS.
Start the computer with F2
Launch CSM: Enabled
Boot Device Control: UEFI Only
Boot from Network Devices: UEFI Driver First*
Boot from Storage Devices: UEFI Driver First*
Boot from PCI-E Expansion Devices: UEFI Driver First*
In the advanced tab do NOT set SATA to RAID. Leave it ACHI
In the advanced tab find the AMD PBS setting and change it to RAID
In the advanced tab you should see the RAIDXpert Raid Configuration option now.
I can't give you exact steps for this, but you may need to delete any arrays, and Please do not initialize the physical disks to create the array....create the array to Both modus...Once you have created your array, move to the next step.
Reboot
Boot from windows USB and begin installation.
On the installation screen where you choose your boot drive, you won't see the array yet. Click on Load Drivers and navigate to your drivers USB to raid-windows-driver-9_01_00_018/ WTx64 (
http://www.mediafire.com/file/a2dln7..._01_00_018.zip). You will have to load 3 drivers You have 3 folders and you want to load 3 drivers
Go to first folder RCBottom and install rcbottom.inf
go to the second folder RCConfig and install rcraid.infto
(you should see now you will see 2 big and 2 small ones Partition a Hard Drive in screen ..or 3 if in system 3 have NVMe.... do not be afraid)
the third RCConfig and install rcnfg
Now you should see the raid array. Install windows on the array.
Once Windows has booted, Windows loads now. Please install only the drivers that I have loaded here. Be careful when installing other chipset or RAID drivers
Well, before I forget, please do not install the Samsung NVMe Driver if you're ferich ... otherwise have a bluescrenn after restar
And another thing, Raid to create after this video (
https://youtu.be/csiqG_rkSWI) you can forget ...for bios bootable raid
Please install only these driver and only this utility
http://www.mediafire.com/?7rnh3rgo4o3l9tell me if it is good
Good luck!:cool:
OLD
NEW
