Need help, Asus zenith extreme + samsung nvme 960 pro.
jacklolita
Hi !!!
Im tired trying install samsung 960 pro into a asus zenith extreme.
Someone with the same Mobo and a samsung nvme (or another) , can tell me if in the bios / advanced / onboard devices configuration , appears the nvme ?? conected in M.2_1 or into Dimm.2_m.2_1 or into dimm.2_m2_2 ??
If the nvme appears in the bios , how you install it ? or what bios you used?
i try a lot of configurations and bios, and never see the nvme in the bios, only recognized in boot section, but in the ezmode sata information, never apperars. It say M.2_1 N/A
Dimm.2_m.2_1 N/A
dimm.2_m2_2 N/A
and no options nvme configurations appear into the advanced mode.
Someone can help me please. I only need if someone see the nvme into de bios ezmode sata info or into onboard devices...and if you can see them, tell my the bios you are using, and how you install it. thanks a lot.
i dont know if the mobo is broken , or is a bios problem. I try to conect in another m2 slots, (dimm2 , m2_1...) and not appear. I used another nvme and never appears.
i tried it with 2 different samsung 960 pro and nothin change.
In my bios i only see that;
69748
69749
thanks a lot.
15 REPLIES 15
Hello friends,
I tried all you said, and finally i got it!!!!
But with a lot of problems.
To another people have the same problem, the conclusion is that nvme not appear in bios advance menu, only appear in boot tab.
But it works .
I put de nvme raid 0 booteable in the bios correctly and installed windows on it with de steps of DIMITRIOS AND SPADIZZLE.
It works with bios version 0902, but at last i decided not installing windows on it, because when i benchmark the raid with windows , the benchmarks were low speeds. I dont know why, i suppouse the cause is windows working on it.
Then i use (ssd cruzial normal ssd) to install windows on it. and create a raid 0 with de other two nvme samsung , and now the benchmark is awsome!!!
To install raid 0 with awsome speeds benchmark using another ssd with windows i use that video:
https://youtu.be/csiqG_rkSWI
But using the new drivers raidxpert2 on windows , not into the bios.
bios version 0902
I clear cmos, install the nvmes harware, install windows in another ssd( normal ssd) and in windows, i install these drivers :
In the asus zenith extreme drivers and tools (last sata driver)
Versión 9.1.0.18
2017/12/27533.53 MBytes
AMD RAID Driver
IMPORTANT:
To protect your data; always perform a backup prior to installing any new, major hardware or software.
If you are adding NVMe as RAID to your existing RAID arrays, update all existing RAID controller drivers to latest version and reboot the system.
Later connect NVMe and install RAID driver on the NVMe devices.
Install the RAIDXpert2 , and install the amd aplication, a new tab appears saying something about raid need to be in bios ... only say yes and install.
Do no touch nothing into de bios, defoult settings.
When you reboot, enter the raidxpert2 application web, create an accuount, (admin admin x example) and in the aplication you will see the 2 nvmes , create new raid 0 selecting the 2 nvme and create.
THen in windows give format like in the video, and you got it.
Speed is awsome!!!
But this is only if you dont install windows in thr raid nvme.
If i choose installing windows with your steps, dimitrios and spadizzle, it works fine, but i dont know why benchmark was very low speeds, comparing benchmark with raid 0 without windows in the raid.
Can you post youy benchmark with the raid 0 nvme with windows installed in the raid??
THanks a lot
If I understood you well. My own raid ...
70008
...but with fan ...:cool:
70009
70010
and with these programs still in the background....
70011
OLD
NEW
Dimitrios1971 wrote:
How to Set Up RAID on Your Asus Zenith Extreme & AMD Ryze Threadripper (nvme, SSD, HDD)
69813
NVMe and SSD drive RAID installation AMD Ryzen Thread Ripper on ASUS Zenith Extreme With BIOS version 0801 or bios version 0902
Know that just as windows needs to be rebooted after changing certain settings, so does your BIOS.
Start the computer with F2
Launch CSM: Enabled
Boot Device Control: UEFI Only
Boot from Network Devices: UEFI Driver First*
Boot from Storage Devices: UEFI Driver First*
Boot from PCI-E Expansion Devices: UEFI Driver First*
In the advanced tab do NOT set SATA to RAID. Leave it ACHI
In the advanced tab find the AMD PBS setting and change it to RAID
In the advanced tab you should see the RAIDXpert Raid Configuration option now.
I can't give you exact steps for this, but you may need to delete any arrays, and Please do not initialize the physical disks to create the array....create the array to Both modus...Once you have created your array, move to the next step.
Reboot
Boot from windows USB and begin installation.
On the installation screen where you choose your boot drive, you won't see the array yet. Click on Load Drivers and navigate to your drivers USB to raid-windows-driver-9_01_00_018/ WTx64 (http://www.mediafire.com/file/a2dln7..._01_00_018.zip). You will have to load 3 drivers You have 3 folders and you want to load 3 drivers
Go to first folder RCBottom and install rcbottom.inf
go to the second folder RCConfig and install rcraid.infto
(you should see now you will see 2 big and 2 small ones Partition a Hard Drive in screen ..or 3 if in system 3 have NVMe.... do not be afraid)
the third RCConfig and install rcnfg
Now you should see the raid array. Install windows on the array.
Once Windows has booted, Windows loads now. Please install only the drivers that I have loaded here. Be careful when installing other chipset or RAID drivers
Well, before I forget, please do not install the Samsung NVMe Driver if you're ferich ... otherwise have a bluescrenn after restar
And another thing, Raid to create after this video (https://youtu.be/csiqG_rkSWI) you can forget ...for bios bootable raid
Please install only these driver and only this utility
http://www.mediafire.com/?7rnh3rgo4o3l9
tell me if it is good
Good luck!:cool:
Thanks I got it to work 🙂 though the three drivers you said to add didn't work in the order u said to least for me it wasnt right 🙂 the raid driver had to go first 🙂 anyway bootable raid up and running great thanks for the info
GeekhomeGamer
Hi :).
This is normal because the protocol used is not SATA.
Don't worry, it's normal (for now)... all you have to do is set the boot/Priority section.
jacklolita wrote:
Hi !!!
Dimm.2_m.2_1 N/A
dimm.2_m2_2 N/A
69748
69749
thanks a lot.
Joscofaie0417
Hello all,
I just install one samsung 970 Evo to my MB Asus Zenith x399 on M.2 port not DIMM, I got the same problem. I followed what you had said before I was able to install windows but still not show up on bios and not able to boot windows normally or select Samsung 970 Evo to boot priority.
