11-02-2017
05:52 PM
- last edited on
03-05-2024
09:47 PM
by
ROGBot
11-05-2017 08:02 AM
haihane wrote:
i'd like to think i'm especially sensitive to tones and infer the intent someone has when saying certain things, and i can tell you that i feel no malice in the earlier guy's message to you. (i don't think he is out to be mean to you.)
would you be willing to attach some pictures of the insides of your pc (motherboard view)? in hopes that we might be able to see something that could lead to the source of the problem.
11-05-2017 02:56 PM
haihane wrote:
why is that cover still there? did you install the threadripper yet?
11-06-2017 12:46 AM
11-06-2017 04:32 AM
Follo wrote:
Are you sure, that you are using the right memory slots. I don't have that board but the manual shows different slots. You are using A1 and B2, but the Manual shows C1 and A1 for dual memory.
11-06-2017 05:51 AM
11-06-2017 07:41 AM
Follo wrote:
Sorry, couldn't see it right on the picture. Cann you post your exact memory (the code after the name)? Is your memory on the compatibility list of this board? I heard that Threadripper has problems when it's not a real dual or Quad Kit. So, when you use 4 sticks it has to be a real quad kit and when you use 2 sticks a real dual kit.
11-06-2017 07:54 AM
Ljugtomten wrote:
This is not correct.
Dual / Quad kits is only a convenience for the buyer, that all sticks are identical.
There is usually not any problem to combine two Dual-kits to run Quad, as long as there is no major differences such as Samsung + Hynix instead of all sticks Samsung. Two diffenrent fabricators would make them hard to overclock.
11-06-2017 08:20 AM
Follo wrote:
Sorry, couldn't see it right on the picture. Cann you post your exact memory (the code after the name)? Is your memory on the compatibility list of this board? I heard that Threadripper has problems when it's not a real dual or Quad Kit. So, when you use 4 sticks it has to be a real quad kit and when you use 2 sticks a real dual kit. It can also be that you CPU has an error. Was it easy for to install the cpu or have used a lot of pressure. Maybe you can try it without the Gpu and or cpu, just to check the error codes.
Try to Reset the bios or the safe boot button. Which LED beside 24 pin connector is glowing? What says the OLED Display. So you can't even go into bios (uefi), or?
And do you have 8 Pin power plugs connected? Molex (EZ-Plug) is just for more Power on the PCIe Lanes when you have single gpu you don't need it.
11-06-2017 08:46 AM
