Liquid Cooling Kits on AMD 1950X
Retired
Not applicable
Hey everyone,
Just wondering on your thoughts on the liquid cooling kits available on the market for the AMD 1950X?
I have Thermaltake's Water 3.0 Ultimate kit. At idle, depending on my room temperature, the cpu temperature's ranges from 29~34 degrees Celsius. When I play DOOM, it's almost stable at 44 degrees Celsius. My system is overclocked. I'd like to compare my temperatures with yours, so I can get any idea if this kit is truly great 🙂
Arne_Saknussemm
Level 40
Have to say, that's a bit of a difficult ask...you'd have to be testing in very similar conditions to get a meaningful comparison...
But from my own testing, if you're idle temps are 2-3 degrees above ambient you're doing well...
Retired
Not applicable
Sound's great to me 🙂
