Lightweight, simple fan control app
teshreve
Looking a simple Windows app that can adjust the RPM of fan connected to an Asus Zenith Extreme.
Would prefer it not be bundled with other apps, utilities, etc.
The less fancy, the better.
Thanks!
4 REPLIES 4
BigJob
Thanks for the suggestion.
Gave it a whirl. It did not recognize my fan controllers on 1st launch. Then did. Then didn't. And the times when it did, I could not find a way to adjust them.
The pre-loaded motherboard options in a few of the drop-downs made me giggle a bit 😉
Blast from the past.
What is the Asus fan control software called? And can I install it all by itself? Is it any good?
BigJob
Ahaha that thing looks ancient, I'm surprised it even installed let alone recognize it half the time.
Give the Asus Fan Xpert a try
https://www.youtube.com/watch?v=fIJ34XFlB40
Hi
I tried both SpeedFan and Fan Xpert, and both wouldn't install and would just leave me with a "running in background" cursor for 10 seconds, and then nothing...
I was searching for a fan controller for my GL703VM (that is to say a laptop), and nothing does the job, i just would not install :'(
Could you help me ?
