01-07-2018 01:33 PM - last edited 3 weeks ago by ROGBot
01-08-2018 06:10 PM
01-09-2018 02:50 AM
Cory29 wrote:
see what this says
https://www.hwinfo.com/
it can show all the temp sensors on the cpu * there are allot and it can be confusing
most of the readings or temps that are off are off by 27 degrees or more - or +
so you will start to see next to negative numbers if you have good watercooling ..
it is dangerous because you could easily hit high temps without realizing it. .. for a while I had one of the sensors tucked next the cpu its was if its touching the side of the cpu and its is in the ball park of what you are reading with other software then I would trust the software.
