Front Panel USB 3 Question
dusty459
Hi Guys
right I'm Using
themeraltakes w100 case and the Front 4 Usb 3s Have Two Separate 20 pin Cables I can only Use 2 Usb 3 on the Front Due to not another 20 Slot on the Motherboard Question is Iv got a 20 pin Splitter which allows 2 20 pins through one 20 pin Head Will it Identify all 4 ports so I can use of them
5 REPLIES 5
dusty459
anyone got an idea?
Ljugtomten
I don't think that would work..
Better to get an internal USB 3 hub and do it properly 🙂 Some people wrote here that it probablt won't work: http://www.overclockers.com/forums/showthread.php/724214-Y-Splitter-for-20-pin-USB-3-MOBO-connection
I had the same problem with the single USB 2.0 header, and required 3 headers. (Corsair Link for PSU and CPU Cooler + USB 2.0 connections in case).
Bought this, which works very well: https://www.nzxt.com/products/internal-usb-hub
Hm Its annoying W100 Thermaltake case Needs 2 20 pins to allow 4 front Usb So I only have use of 2
JHR1979
the zenith extreme does have two internal usb3.1 headers (plus one usb3.1 gen2 header), one at the side of the motherboard, second one at the bottom part of the motherboard.
masterac
usb 3.0 port requier 2 port per cable, you do realise having a ****load of usb connector on the same cable would decrease the speed of those usb the board has a lot of usb 3.0 on the back, i would suggest an usb hub, even better if you find one that work on usb type c, so you are sure to have better speed even on more port
