Fan smoothing stopped working?
JackBauerz
I'm having fan oscillation problems... Under a fairly constant reasonably low load (for my TR 1950x, 64GB, SSD only machine)...
My CPU fans are oscillating every 30 seconds or so... Which of course leads to CPU temps oscillating... Process continues.
Previously fan smoothing in BIOS prevented this. It no longer works. I did update bios to 1601 a couple months ago... PITA as it wiped settings I had to re-establish (I guess it's been so long since I touched a BIOS I didn't think that would happen)
There's a new BIOS out there.. 1701, but no indications this was fixed in 1701.
Anyone else see this and have any advice?
Cory29
I noticed this too I had to install the AiSuit to control it - ive had mixed luck with other software
Whenever I install a new uefi there seems to be strange ghosting cache issues for about a month ... I think most of the problems like this is a bug with the uefi chip that is being ignored
