09-15-2017 06:26 AM - last edited on 03-05-2024 09:52 PM by ROGBot
09-15-2017 08:32 AM
AdayaB wrote:
Is this just a one off extreme issue with power capacitors or is this even more wide spread?
09-15-2017 12:04 PM
09-15-2017 12:21 PM
Cory29 wrote:
I have the same ram issues - before 9960 I couldn't boot with DOCP settings
(even with setting T2 *I don't think the board is saving settings correctly everytime i restart into uefi some settings are different or reset to default)
now with the latest I can boot into windows fine open and close programs fine but when I try to run a game or render something instant crash
For the correct temp check out ryzen-master
http://www.amd.com/en/technologies/ryzen-master
*since you have a loop you can stick one of these in your fill port it will stop the fans for going crazy for when your cpu randomly spikes unfortunately I don't think you can't change the temp source for the cpu header :mad:
https://www.amazon.com/dp/B01HQ8LKBQ/_encoding=UTF8?coliid=I3OZ7UEQ0QJWP3&colid=11KUTS4O2RUKT
there is also a new updated chipset driver that might help with other issues
09-15-2017 03:53 PM
09-15-2017 05:42 PM
AdayaB wrote:
Installed Ryzen Master, and it just confirms my suspicion of temperature fluctuation, every second it's changig from 42c~52c; obviously this is pretty unacceptable for a watercooled solution. on top of that, installing those rgb firmware updates, doesn't seem to have did much of nothing. If i can't even play my favorite game (Dota 2) on a $6500 rig, it's worth diddily squat. has there been any official statement from ASUS on these issues?
09-15-2017 06:31 PM
Ljugtomten wrote:
I'd say that either your cooler is broken/crap or you did something wrong when you mounted it and applied thermal paste between pump block and CPU.
Is the pump working at all?
09-15-2017 07:57 PM
09-15-2017 09:06 PM
09-15-2017 09:52 PM
