09-15-2017 06:26 AM - last edited on 03-05-2024 09:52 PM by ROGBot
10-08-2017 10:51 AM
10-04-2017 07:17 PM
10-09-2017 01:12 AM
ramin_rostami wrote:
important = 2 single channel ram NOT dual ,,,, 4*dual channel ram NOT quad so you must use real 4 quad channel ram(4 ram in 1 box writen quadchannel on it ) , not 4* dual channell*
in ryzen you must use only *dual channel , never never use 1*single channel ram , your system cant start , even start will give you tiny freeze
example true ram for threadripper
gskill ripjaws4 2800 4*4*
example true ram for ryzen and all other amd
geil evo x 3200 2*8
or
gskill RGB trident z 3200 2*8
NOTE=true slot ??? in AMD you must put ram in exact slot , according your motherboard user manual , so before put ram on ramslot see your mobo true ram slot (wrong slot can make system cant start or crash )
in amd ram is very very very sensetive ,but if you use no1 best ram, you never see even 1 freeze,bluescreen or freeze hang in 1 year !!
10-18-2017 06:28 AM
AdayaB wrote:
Firstly, after almost 7 years, decided to go head in on a full blown new build to replace my
Core-I7-950
EVGA X58 Classified 3
EVGA NVIDIA GeForce GTX 980
G.Skill 24GB DDR3-1833MHz
12TB of HDD Space
Dual 28" ASUS 3D 144Hz, 4K Monitors
1000W Thermaltake PSU Gold Rated
for
AMD ThreadRipper 1950X
ASUS ROG Zenith Extreme X399
MSI AMD Radeon RX Vega 64
G.Skill 32GB DDR4-3200Mhz
2x1TB Samsung 960 PRO NVMe
Single 49" Samsung CHG90 144Hz QLED
Seasonic 1000W Titanium PSU
and this new AMD has been a complete f!@#ing disaster, a disappointment and money not well spent. So from the start, originally had order a Corsair H115I AIO Cooler for the CPU and G.Skill TridentZ RGB Memory, the memory would not post under any configuration, and i do mean any, from single slot tries in every slot to different dimms placed in various MB spec orders. So sent the TridentZ back (ruined my RGB theme) for G.Skill HyperX memory which was suppose to be compatible with Ryzen chips. well yeh, got it to post after reversing how the slot was configured, but not to the MB Specifications.
Before I get into the wealth of issues with the HyperX memory, when the system post, the tempature was insane on the CPU 63-71C, did everything trying to see if maybe the CPU install was bad, nope everything looks proper, than thought maybe the H115I was bad, so sent that back for a refund, and went with an EKWB Water Cooling solution. Hrm...Nope, system still booting with 63C~ Okay, so run through the OS install process, thinking maybe the cpu-monitor is just wonky etc, install steam with some games, launch 3dmark, BAM! system shutdowns with the LED on the MB stating CPU Temp etc. Okay
Booted back in, downloaded the latest bios 0503, oh hey the CPU temp dropped to something reasonable 32C~-43C, but notice the s#$! sparaticuly jumps around in all types of temparture ranges...weird, but more stable before, attempt to set the memory to correct timing from auto etc, 14-14-14-34-3200Mhz DOCP, boot back into OS, seems okay, input devices are wonky. crank into my favorite game (Dota 2), within 5m, my system shutdowns, repeat this everytime.
Now mind you, this buld is in the $6500~ range, and I am beyond mad and pissed off with this. Right now, every indication of problems point to this motherboard. I am in complete utter disgust, that paying $549 for an ASUS ROG Zenith Extreme has been my bane for this entire project. right now I have a $6500~ unusable piece of crap because my tempartures are wonky and memory is just not function properly.
Is this just a one off extreme issue with power capacitors or is this even more wide spread?
