Corsair RGB 3466 memory won't post in zenith extreme
gingdry
I have the Corsair vengeance RGB 3466 32GB (8x 4) (CMR32GX4M4C3466C16 v.4.31), but it won't post in zenith extreme with 1950x,
I already updated to latest beta BIOS 9910 and Q-code still shows "1F", so I am using my old set of G.skill 2666 instead.
I checked the latest Qualified Vendor List (QVL) and find out there is only one set of Corsair memory rated at 3466 is supported (Part No.: CMK32GX4MB3466C16 ver 4.31). However, There is no such Part Number existed in Corsair homepage?! Is it a typo in QVL?
Anyway, I just hope Asus will add support to RGB 3466 as well as the Corsair RGB 3333 is already on the supported list.
Bill
Hello gingdry
Thank you for your inquiry.
I'll consult this with our team and I'll get back to you once I have more info
Thank you
Bill
Hello gingdry
I've confirmed this with our team that it is a typo!
The correct part number should be: CMK32GX4M4B3466C16
We'll correct this in our QVL. Also, our team does not recommend you using BIOS version 9910
Please make sure to follow up to the latest BIOS released officially from our support site
Thank you
