Purchased from Aliexpress, on visual inspection seems like was worth the wait coming from far east
😄 . This should be an improvement over the
EK-Supremacy EVO Threadripper Edition.
RGB is not my cup of time but the store that had the best price sold the product with Bykski RGB/AURA . So loose in parcel was
Bykski RGB unit, it has 6 connectors, 3 per long side of unit, each with 6 pins, labelled as fan 1 to 6. One short side has 2 connectors with 4 pins labelled as RGB. Other short side has DC 12V 2 pin to molex with pass through, 5 pin labelled as IBM, which has 3 wires to a LED in metal casing :confused: . No manual in box and no idea on usage, nor was there a plan to use it TBH
Bykski A-Ryzen-ThV2-X has a nice weight and good finish IMO :cool:. This V2 edition also supports AM3/AM4 as well as Threadripper, read and weep EK
😛 . 3 sides are clear and one long length has an integrated LED unit, this has 4 pin connector and 50cm of cable. There seems to be an 4 pin extension cable included or maybe part of Bykski RGB unit :confused: . Cold plate has a fine machined finish, I may lap it at some point, doesn't seem too shabby at all. Looking forward to plumbing this in
😄 and comparing to EK :rolleyes: .
On the rise and fall of the clock cycle...
