BIOS 1402 Problems / Questions
mylala
hey guys,
i've two questions about the new BIOS 1402:
- There is a "EVALUATION COPY"-Text before the BIOS-Screen is showing up while starting up the boot process. What's this about?
- 1402 is pretty instable for me and i get a lot of crashes under w10/64. I was pretty fine with BIOS 1003, but when i try to go back to the previous version, i get an error msg that the bios image does not fit into the bios ROM. Same with all prior BIOS versions and no difference between ezupdate/bios update. Is there a workaround for this?
kind regards,
myla
10 REPLIES 10
Martsmac1982
Yeah except when you didn't realise it worked this way when you built it and your rig has a custom loop on it so it's a massive PITA to take it apart and move them lol.
My Rig.
Caselabs STH10
AMD RYZEN THREADRIPPER 3960X
ROG ZENITH II EXTREME
64GB G. SKILL DDR4 2800 (F4-2800C15Q2-64GRK)
1 x RTX 3090 WC 24GB
1 x ADATA 2TB 8200 NVME for Games
1 x CRUCIAL 500GB NVME purely for OS
1 x 960GB Crucial SSD for Downloads
