08-28-2017 06:23 PM - last edited on 03-06-2024 09:18 PM by ROGBot
08-28-2017 06:41 PM
08-28-2017 08:34 PM
08-28-2017 10:52 PM
'[azathot wrote:
;671010']Howdy,
I called ASUS tech support and they were rather confused, so I figured I would ask in the forum.
I have an existing NVME (Samsung 960 Pro) in slot one, under the heat sink.
I have a secondary NVME (Samsung 950 Pro) I would like to use. I have installed the M.2 drive in both of the slots on the DIMM.2 to the same result.
I have two 1080Ti (ASUS Strix) installed as the video cards in the machine.
When the DIMM.2 slot is installed, the machine fails to POST and reports the error:
B2 - Failed to load Video BIOS
Removing the DIMM.2 slot allows the machine to boot and be fully operational.
Removing one of the video cards nets the same result.
Has anyone successfully used the DIMM.2 slot to add an additional NVME to their system? Is there a secondary config option that is necessary in order to enable this functionality on the board?
Thanks!
08-29-2017 12:06 AM
08-29-2017 04:23 PM
02-20-2018 08:14 AM
02-20-2018 10:17 AM
Skillividden wrote:
By the way, I could not overclock my 64Gb memory kit (Corsair LPX 3000 cl15) to 3000MHz. It is stable only up to 2800MHz. The kit is listed as recommended/tested for the Zenith Extreme. I'm not sure whether it's a memory issue or motherboard/BIOS problem.
02-20-2018 11:18 AM
02-20-2018 11:23 AM
Skillividden wrote:
Yes, it's definitely not Samsung b-die. But for me, 2800MHz instead of 3000 is not really a problem, at last not a major issue.
Skillividden wrote:
As I wrote I have almost the same issue with error b2 and dimm.2 slot.
