Asus Zenith Extreme x399 Restart circle stuck for 2 seconds
Jesse92
Hi guys. I got a issue with my Zenith Extreme x399 so everything works perfectly fine when i get into the system no delays in starting windows, the only issue I have encountered is that everytime when i have restart, Asus logo pop out as ıt should be and there is circle that moving around beneath the logo and in normal case it was spinning like 2 times and then disappear and then eventually screen was coming but now that spinning circle hangs for 2-3 seconds then screen comes up, is it normal?
I am running on windows home 1809 version
Thnx in advance for help 🙂
Retired
Not applicable
Jesse92, which BIOS is implemented to your system? I have 1601 but no feature like yours. Overall, if everything is functioning the way it's suppose to be, I wouldn't worry about it 🙂
drop4205
Level 12
on a restart it is normal. Its not being shut down in a sleep state so everything is restarting again
Strix X870e-e / AMD 9800x3d / Gskill 32gb 6000 / Crucial T705 / ASUS Prime 9070 XT / Lian Li 011 compact / Lian Li Hydroshift AIO / Lian Li Platinum 1300 psu / Windows 11 24h2
