ASUS ROG Zenith II Extreme Alpha, post error
Tux-box1
I'm getting a "Post error" message on the Live Dash OLED. Not very descriptive, I agree but that's all I have right now to go on.
I've tried the following:
Removing the CMOS coin cell
Pressing the CMOS reset button
Performing a BIOS flashback, 2402 the last one I was running. I'll worry about the TPM firmware update later.
The BIOS flash back appears to work I get a green CHECK
Tried both BIOS'
Removed all but 1 stick of ram, installed DIMM_A1 per manual
Removed all m.2 disks
Reseated CPU and Cooler
Enabled "slow mode"
Used the "safe boot" button
Tried with and without GPU, a simple old school passive cooled gtx260
yet every time I attempt to boot I get "post error" on the LiveDash.
I'm really hoping anyone can offer any suggestions or advice or direction.
Any feedback is greatly apperceived.
thanks.
Tux-box1
I would like to add: the bios LED light next to the 24pin motherboard connector does turn green.
