ASUS ROG Zenith II Extreme Alpha: cant update from Bios 1303 to 1402
Mappi75
Never had this Issue on all of my Asus mobos with the same usb stick.
But this time the Bios Flashback Button Update (which i always use) did not work for me.
Tried this for months, reset Bios before updating and so on..
now i tried this all again..
Someone else have this problem too?
Now i use the bios built option to flash the bios,
which works.
But even now i cant update via Bios USB Flashback button..
Mappi75
Hello, it was really the usb stick which i used for 4-6 asus pc systems atm.
I used another (old) stick and this time the update worked on Bios 1 & Bios 2.
Mappi75
I tested the old usb stick and it dont have any issues or defects.
tested it with windows 10 inbuilt checks + ChkFlsh + h2testw (from c't). No errors at all.
