Asus rog zenith extreme slot spacing
Juggalo23451
I am just wondering what sli hbm i should get also the ek terminal block.
I am thinking the 3 slot should work. Is my assumption correct.
Thank you for your time in advance
9 REPLIES 9
Arne_Saknussemm
Level 40
Hey Juggalo23451
You want to be using the first and third reinforced slots for x16x16 SLI...so you will want the 4slot SLI Bridge...there is a 4 slot tripple bridge in the box but it aint so pretty...i presume you are looking for third party...
71261
The EK bridge you'd want something like this...tripple block https://www.ekwb.com/shop/ek-fc-terminal-triple-parallel
(Depends on your GPU block...they have these too https://www.ekwb.com/shop/ek-fc-terminal-x3-s-acetal)
but don't forget to get a blank for middle...
I'm a parallel advocate in case you hadn't guessed...
Juggalo23451
Yeah I usually have my gpus in parallel. Looks like I need to take back my sli hbm because it is a triple slot not four. Just another reason to go to microcenter. Thank you for your insight.
Juggalo23451
I ordered the parallel block and the terminal blank I am assuming I will have to get screws for it
Which ones exactly? But it's been my experience with EK that they always come with what you need to set up in terms of screws etc.
Just check the installation manual for what you bought on their webpage
I got this block terminal block
http://www.performance-pcs.com/ek-fc-terminal-triple-parallel-plexi.html
This is the terminal block blank I got
http://www.performance-pcs.com/ek-fc-terminal-blank-parallel.html
Arne_Saknussemm
Level 40
Yeah, that blank works with the screws on the block...
71354
So you should be good to go!
71354
Yes it does. I was trying to look at the PDF on my phone and it did not load all the way 🙂
Juggalo23451
Alright wc blocks installed, terminal block is installed. Thanks again. Two titan Xps FTW
Arne_Saknussemm
Level 40
