ASUS ROG Zenith Extreme CPU Code 00
akrovatis
I have installed some updates from Armoury Crate. Asus Framework Service, Asus Core SDK, Asus ROG Zenith Extreme Alpha (HTML / HAL / AURA Kit / Device SDK)
After restarting my system, I got a CPU "Code 00" on the screen of the motherboard.
Well, the problem seems to have been solved after a few attempts of restarting and applying optimized defaults in the Bios. The only thing it changed was after Hybernate, Stealth Mode ON. I have installed the iQue Software of Corsair for my keyboard and sometimes with the combination of AURA kit does some crazy stuff. For example when I load "Rainbow Mode" one of my RGB memory sticks has different color from all the others.
6 REPLIES 6
gupsterg
Level 14
I wouldn't run 2 or more differing RGB software on Zenith Extreme and Zenith Extreme Alpha. The software can clash with one another, also the Super IO chip can have issues with software which accesses it and does not use a feature called ASUS WMI.
Intel Defector :eek: AMD Rebel
So, how am I supposed to have my keyboard working without its software? This is insane! The only solution is to choose one of them?
It happened again. Error Code 00
Consider reseating the CPU and CPU cooler.
Sorry I have no solution to share on this, I just thought I'd give you the information.
Others have had this issue, link. No idea on solution.
I have used 1950X & 2920X with ZEA and not encountered this issue. Each time I also did not even use the AMD torque tool, but just tightened socket screws with normal torque bit and screwdriver.
I have also used 2 sets of RAM now with ZEA, F4-3200C14Q-32GTZSW & F4-3200C14Q-32GVK and not encountered issue.
Sorry no solution I can share.
Dimitrios1971
Level 12
