Asus release BIOS 0804 for Zenith Extreme
Dimitrios1971
Level 12
http://dlcdnet.asus.com/pub/ASUS/mb/socketTR4/ROG_ZENITH_EXTREME/ROG-ZENITH-EXTREME-ASUS-0804.zip
Edit 9.12.2017
Asus today has the changelog release for BIOS 0804
1. Improve memory compatibility
2. Fix CPU abnormal temperature after clearing CMOS
3. Fix CPU/CHA Fan EQ mode issue under AI-suite 3
4. Fix PWM and DC mode display error for EXT_Fan under Fan Xpert
NOTICE: If you are upgrading from beta BIOS 0801 and have a SATA/NVMe RAID configuration, backup your data and remove the array before updating to this build.
If you are updating from any other BIOS version (e.g. 0701) or do not have any drives configured in RAID, you may update normally.
OLD
NEW
31 REPLIES 31
Yes, the RAID support was reset to 804 and the 804 retired. RAID support should come with the next verion again
OLD
NEW
bios 0804 is back in BIOS & FIRMWARE 😛
OLD
NEW
