Asus release BIOS 0804 for Zenith Extreme
Dimitrios1971
Level 12
http://dlcdnet.asus.com/pub/ASUS/mb/socketTR4/ROG_ZENITH_EXTREME/ROG-ZENITH-EXTREME-ASUS-0804.zip
Edit 9.12.2017
Asus today has the changelog release for BIOS 0804
1. Improve memory compatibility
2. Fix CPU abnormal temperature after clearing CMOS
3. Fix CPU/CHA Fan EQ mode issue under AI-suite 3
4. Fix PWM and DC mode display error for EXT_Fan under Fan Xpert
NOTICE: If you are upgrading from beta BIOS 0801 and have a SATA/NVMe RAID configuration, backup your data and remove the array before updating to this build.
If you are updating from any other BIOS version (e.g. 0701) or do not have any drives configured in RAID, you may update normally.
OLD
NEW
31 REPLIES 31
I was able to get my system up to 3066 using just voltage settings and specifying the freq. When I try 3200 tho, no boot.
I noticed that the manual states the 2 sticks should be installed in slots C1 A1, while the QVL states "2 DIMMs: Supports two (2) modules inserted into one pair of dark gray slots as one pair of Dual-channel memory configuration. Install the modules into slots B1 and D1 for better compatibility."
I would expect ASUS to at least put enough effort in to it's product to insure that it's documentation would agree with it self.
I physically checked the ram I have and it is single ranked, which leads me to believe it's Hynix.
Then I found this nugget here:
https://www.reddit.com/r/Amd/comments/62vp2g/clearing_up_any_samsung_bdie_confusion_eg_on/
In general (on Ryzen) you can expect up to 3466 MHz (without BCLK-OC) with Samsung B-Die (on AGESA 1.0.0.6+ Bios Versions), up to 2933 MHz (without BCLK-OC) with Samsung D/E/S-Die (AGESA 1.0.0.5+). Hynix A/M-Die are mostly working @ 3200 MHz with AGESA 1.0.0.5+. Do note that Dual Rank RAM is faster than Single Rank. E.g. 2933 MHz Dual Rank is faster than 3200 MHz Single Rank. Single/Dual Rank is not to be confused with Single/Dual Channel (Dual Channel is always better).
https://linustechtips.com/main/topic/837324-ryzen-ram-rated-for-3200-stuck-at-3066-ideas/
Your specific kit of ram could contain either of two different types of chips. If the chips on the stick of ram are on both sides (dual rank) then you've got Samsung D-Die chips. If the chips are all on one side (single rank), you've got Hynix M-Die. Source
I give this information because Ryzen simply may not be capable of running your 3200MHz rated kit at 3200MHz. Ryzen boards have gotten much better with ram compatibility, but not every ram kit will work with every board. It's just too early in the Ryzen platform to have all the kinks worked out.
You could try manually setting the voltage to 1.4 and trying 3200MHz. You could change the command rate to 2T instead of 1T. You could loosen the timings a bit more, 18-18-18-18-38. Or you can live with 3066, to be completely honest, you'll never notice the difference.
Any one have a confirmation on if AGESA is compatible with hynix ram with the way AGESA changed in 804?
rich345
Edit 9.12.2017
I followed the instructions and removed all arrays before updating to this build and I still can't find the "Enable NVMe RAID" command.
masterac
i put my ssd m.2 where it should be , the port right on the motherboard, are you telling me the dim has x8 enable ????
These settings are not yet visible in RZE's BIOS (0801-0804)
You mean something like that...
69511
69512
69513
OLD
NEW
has asus returned the bios 0804?
69633
OLD
NEW
I just checked and it looks like they've pulled the 0804 update. Hopefully they are adding the NVMe RAID support that everyone expected to be in it originally.
I also hope:cool:
OLD
NEW
69511
69512
69513
first time i see this, but it seem its not the same sub menu
mine is
71175
eco_bach
Any news yet? Has RAID support returned to 804?
