09-01-2017
03:47 PM
- last edited on
03-05-2024
10:00 PM
by
ROGBot
09-01-2017 07:13 PM
09-01-2017 07:50 PM
09-02-2017 09:50 AM
Mikan02 wrote:
Hi.
Is this one 64GB kit or two 32GB kits? Asking cause you wrote kits and two kits can be more difficult to get stable even at rated speeds.
If two high speed kits matches and start without issues you are usually just lucky.
Have you tried to just enable D.O.C.P without any adjustments to speed, timings or voltage? 🙂
IM3CPO wrote:
One other tip I have had suggested when populating all DIMM slots is to use manual settings (not DOCP), enter all memory timings manually, set voltage on RAM to 1.35v, and up voltage on SOC to 1.25v - 1.35v. Also set Memory Command rate to T2.. Good luck!
09-07-2017 01:59 AM
Enad1 wrote:
Thanks for the info, one thing I'm unfamiliar with on this new CPU is there are two DRAM voltages. One says AB Voltage, the other says CD Voltage? Do I match them? Mess with one and leave the other?
09-01-2017 09:02 PM
09-01-2017 10:18 PM
