This z390a is equipped with a CORSAIR HYDRO SERIES H80i v2 AIO Liquid CPU Cooler, 120mm Thick Radiator, Dual 120mm SP Series PWM Fans, Advanced RGB Lighting and Fan Software Control.
Two settings that seem to relate to a cooler appear in the BIOS, and both are disabled: A10 pump control and water pump + control.
Perhaps a knowledgeable soul can advise whether either setting should be enabled and, if so, to what?
No cooling problems noted and cooler/fan performance is even, so it will be left as is unless there is definitive advice to the contrary.
Thanks
