Z390 Strix-I Gaming | Won't Post With Two Dimms (4133Mhz)
irishj
Hello,
I recently started a mini-itx build, using the Z390 Strix-I Gaming moterboard and 2 x 8GB G.Skill Trident Z 4133Mhz Dimms (F4-4133C19D-16GTZR) but the system will not POST with both dimm slots populated. The dimm led on the motherboard is illuminated in orange which shows there is a memory issue. Removing one of the dimms (nearest cpu) and the system will POST. Tried swapping the modules around to see if it was a module issue, but experience the same issue no matter which module I use in each slot. I enabled XMP1 and rebooted and the system POST's again with one module, turned off and added the second and experienced the same issue again, no POST and orange dimm led illuminated. Memory training is enabled on the motherboard and I've tried disabling it, but no difference.
Let me be straight up and state I know nothing about overclocking, memory voltages ect... so everything is set to auto. Any ideas on possible solutions to this issue ?
Thank You
20 REPLIES 20
