WIFI and BLUETOOTH issue On Z370 E motherboard
Gweek
Hi ,
I bought a ASUS STRIX Z370 E MOTHERBOARD to have an integrated WIFI and BLUETOOTH.
The WIFI and the BLUETOOTH completly disappeared from the device manager after installing an update for my MX MASTER mouse.
I followed every solution I could find on the net :
1. I used the troubleshooting tool from windows
2. I tried to update all the network drivers
3. I restarted the computer after resetting the BIOS. I even unplug the PC from the wall to be sure.
4 I reinitialized the PC
5 I updated the BIOS
6I reinstalled completly windows 10
So now I have a true fresh windows 10.
So, I tried to install all the drivers from the asus site from the chipset to LAN,wireless and BLUETOOTH connection.
Only the Wifi and the bluetooth driver doesnt work and doesnt change anything...
Apart from an hardware issue , I dont see another explanation. Is it possible only the WIFI module got broken and is it possible to replace only this module easily?
Please someone can tell me if there is another solution?
Arigato gozaimasu
chevell65
Level 12
Have you tried shutting down PC, bleed power with on button, unplug from wall for awhile then boot up and see if anything changes.
Z270E had similar Bluetooth WiFi issues which could only be resolved by complete shut down or clear cmos etc.
There are unfortunately many other threads about this type of issue.
https://rog.asus.com/forum/showthrea...how-I-fixed-it
https://linustechtips.com/main/topic...0i-windows-10/
http://www.hyr5.com/f4/t25319
https://rog.asus.com/forum/showthrea...working-at-all
https://linustechtips.com/main/topic...luetooth-gone/
https://www.tonymacx86.com/threads/s....216999/page-2
https://www.reddit.com/r/ASUS/commen...h_not_working/
https://www.reddit.com/r/buildapc/co...denly_stopped/
