12-05-2017 06:44 PM - last edited 3 weeks ago by ROGBot
12-10-2017 08:13 AM
Scotty99 wrote:
Id just like to add that "asus multicore enhancement" on the strix-f is actually intel defaults, plz fix for next bios revision.
Scotty99 wrote:
I want to voice my opinion in here, what is going on with you guys and z370? My strix z70-f bios settings are all over the place, let me explain:
0430
1. MCE is actually intel specifications, but it never boosts one core to 4.7ghz.
2 When you disable asus MCE on 0430 you get a 4.5-4.6ghz all core boost, but with HUGE amounts of voltage, nearly 1.4.
For one thing this is backwards, secondly where is the standard intel specs where you get 4.3ghz on all cores and 4.7ghz with lower volts, it does not exist on 0430.
Beta bios 5430:
I did not try anything other than bone stock defauls as i was merely troubleshooting asus aura, but this is what "optimized defaults" gives:
~4.7ghz all core boost
Greater than 1.4v
Yes this is at bios defaults with xmp DISABLED. If that bios goes live you are going to have people throttling their 8700k's, i am using a 240 AIO and i saw 80c with it just doing windows stuff.
Can you please come out with a bios for the strix -f where asus MCE is a 4.7ghz all core boost with ~1.3-1.325v? This is even on the high end to be stable for all chips. And when MCE is disabled it should follow intel spec, 4.3ghz all core boost and 4.7ghz on one core, not a single bios or mce setting has this in any of the ones i have tried.
COme on bios guys, you can do better than this.
12-09-2017 09:50 PM
12-10-2017 12:31 AM
0430
Beta bios 5430:
Greater than 1.4v
12-25-2017 06:59 PM
03-16-2018 01:42 AM
theWanderer521 wrote:
ROG Strix Z370-e / i7 8700k
Hi new member here. I am no expert in overclocking etc.
I recently bought this PC (all brand new parts) few weeks ago. For being stupid (stupid coz I just updated BIOS just for the update) , I decided to update my BIOS to 5605 from 0419. I also enabled XMP profile. MCE disabled.
Right now I have fluctuating CPU temps that I have never encountered on the previous BIOS build.
Though it is stable like I can boot to Windows..do my normal stuff (browse etc.) It's just I have fears regarding these temps. Should I be worried? Should I downgrade to previous BIOS? I also experienced 85c in normal 3D sketchup renders....
If anyone can try to help and point me on any particular setting to adjust on this latest update I would greatly appreciate it.
Furthermore, I haven't done OC this one or any delidding or any expert stuff. Thanks once again!
12-28-2020 03:23 AM
04-30-2018 03:04 AM
05-10-2018 10:09 AM
