System instable when using AVX negative offset
mplutka
Hi everybody,
I encountered a strange problem with my Z370 STRIX-F whenever using AVX negative while running all cores on multi 50.
If offset is 0, I can run Cinebench for hours at 5Ghz and 1,375V VCore.
As soon as I set negative offset to 1,2,3 or whatever, Cinebench (doesn't use AVX) crashes in under 1 hour (BSOD) with the same settings as above.
I don't get why setting a negative != 0 renders the system unstable (at least with Cinebench).
Thanks a lot!
0 REPLIES 0
