03-10-2019
03:07 PM
- last edited on
03-06-2024
08:35 PM
by
ROGBot
03-10-2019 05:25 PM
JosePedro wrote:
What options do i have to replace this fan, or do i really need it, since i have the cpu at stocks settings (turbo on).
It's very noisy, monitor on Bios gives over 6000rpm.
I would like to replace it for a bigger one, less rpm but i dont now what it really cools down, and if i will have tempateratures problems.
Did anyone had this kind of trouble?
Thanks in advance
03-11-2019 09:09 AM
Enderwiggin03 wrote:
With that tower air cooler you might not even need it.(...) The fan is for VRM cooling.
03-13-2019 05:07 PM
JosePedro wrote:
Good to know that, ill going to take it off and then ill check the temps 🙂
