02-17-2019 05:50 PM - last edited 3 weeks ago by ROGBot
02-17-2019 11:16 PM
02-18-2019 08:28 AM
02-19-2019 09:13 AM
kens30 wrote:
Disable windows hibernation (not needed for ssd) by running this command in cmd.
Run CMD as admin and type powercfg -h off press enter and now restart for it to take effect.
See if that fixes your issue.
If the issue persists check out this thread to update your sound drivers
https://rog.asus.com/forum/showthread.php?105341-DRIVERS-Realtek-HD-Audio-(UAD)
02-24-2019 07:54 AM
02-24-2019 08:45 AM
02-25-2019 08:12 AM
AS185 wrote:
GiJoe_83, I had almost the same problem like yours for quite a while. Try accessing your BIOS and disable option Hot Plug in Sata Configuration. See if it works.
02-26-2019 12:22 AM
GiJoe_83 wrote:
i try this two, and nothing
02-26-2019 12:21 PM
kens30 wrote:
Your audio problems might be installed driver/software related.
Try running LatencyMon 6.70 to check if that's the case.
home page
https://www.resplendence.com/latencymon
download
https://www.resplendence.com/download/LatencyMon.exe
