ROG Maximus X HERO Overclocking Help
layyes
Hello Everyone,
My Specs are the following :
Ram : Trident Z RGB Ram (XMP Activated)
CPU : i5 8600K
This is my screenshot of the overclocking and the different settings of my motherboard, Please guys advice me what options to change to keep my PC From getting BSOD And freezing and please tell me if the temperatures reading and voltage is ok or not
14 REPLIES 14
x-rated
i would recommend you to uninstall this app and use the latest bios instead 🙂
you can try similiar settings for your 8600K https://imgur.com/a/8pWMV29
set VCCIO to 0,95V, System Agent to 1,05V manually, dont touch memory timings and frequency and use your xmp memory profile only
you can keep BCLK at 100,0000 MHz
i didn't get the part of the BCLK what's the use of that ? and is the ram timings you sent is compatible with my ram ?
Are you familiar with using the bios? Start there, and set your ram to xmp settings first.
x-rated
just left BCLK at 100 MHz, dont care about it, you will oc cpu wia multiplier 🙂
i want my cpu to sit at 4.7 its enough with the best stability possible
x-rated
try those settings with x50, you can always lower it
keeping ram only at XMP is ok ?
x-rated
of course, thats why XMP exists
After trying your settings, here are my results . depsite putting 1.005 voltage in the Bios, i get a reading of 1.38 which is i think very high, please advice
