Removing LED's From z370-F
SightUp1
I never wanted the LED's in the first place. I hate LED's. What am I? 15?
The plastic shroud is covering up the VRM heat sink. Seems silly why ASUS would do this... The VRM runs really warm. I want airflow EVERYWHERE I can get it around the VRM. I looked through the I/O connector area and see some wires that connect the shroud to the motherboard. I want to remove that plastic shroud and wires that connect the LED's to the motherboard. Is it possible to remove all of that without the use of a heat gun or soldering?
If my question doesn't make sense, I am linking a picture of what I am specifically talking about. See the red circled area.
https://imgur.com/a/mgLkDn7
4 REPLIES 4
xeromist
It looks like it's fastened from the underside.
cl-Adrian
Try using Asus Aura to turn it off:
https://www.asus.com/campaign/aura/us/download.html
Nate152
There should be a setting in the bios to turn it off as well.
Advanced tab, Onboard Devices Configuration.
Phillyflyer
Check the back of the board for small screws that may be attaching the shield to the board....if none...my guess is that the shield snaps in place via tabs and may need a little pressure to be released....you do this at your own risk though.
Asus ROG Maximus XI EXTREME
Intel i7 9900K OC'D @ 5.2 GHZ @ 1.345V (1.296V LOAD) LLC 6 PRIME 95 STABLE 8 HRS
XSPC RX360 Rad (6)Scythe Gentle Typhoon 1850 RPM Fans In Push/Pull @ 1500 RPMS
Swiftech Drive II / Swiftech MCP35X Pump
Enermax Platimax 1200 Watt Power Supply
32GB G.Skill F4-3866C18Q-32GTZR 3866 MHZ CL18 1.35V (OC 4266MHZ 17-18-18-41-2T @1.45V)
MSI GTX 1070 SEA HAWK EK X SLI WITH ASUS HB RGB
(5)Samsung 840 Pro 128 GB In Raid 0
(2) WD 1TB Black Edition
Corsair 900 D
