problem with ethernet
Zfast4y0u
Hello, last few days i experience weird issues with my internet connection
when i start PC from cold boot, i dont have internet acsess. down right angle near time it say no internet connection, if i go trobbleshoot problem it start looking for problems and it shows trying to reset router or something but it fails. its stuck there.
if i try then to restart pc or shut down it just hangs on *restarting* or *shuting down* and i need to manually reset pc. when pc boots next time, internet works without problems.
i did reinstall network drivers 100x till now and it dosent fix the issue.
i noticed this started since i used DDU to remove nvidia drivers before i install new ones. idk if this is causing some issue or what -.- but it is annoying, having to restart pc manually each time, i can face data loss too at some point i guess -.-
anyone can help me figgure out whats wrong?
my mother board is Maximus X Hero.
0 REPLIES 0
