not starting to power on
radical_mit2
Hi All,
I have a ASUS ROG MAXIMUS X HERO (LGA 1151, Intel Z370, ATX) with an Intel i3 ( 4.0Ghz) series 8 , 2x 16 G memory.
all works really well until, i add ASUS GeForce GTX 1070 Ti ROG STRIX A8G-Gaming.
with a Corsair RM750x
then nothing happens.
I see a while light come on, on the Graphic card. But nothing lease happens.
if i remove the Graphic card the PC boots 100%
I have tried the card in both slots.
Help, anyone have an idea what i need to do?
thanks
tim
SherardG
Is your card powered correctly, and have you moved your DP connector from the motherboard's IGFX to the card's ports?
