10-23-2019 08:15 AM - last edited on 03-05-2024 07:36 PM by ROGBot
10-23-2019 01:20 PM
10-24-2019 02:07 AM
rexbinary wrote:
I battled this for months until I found the fix. You need to disable Fast Startup in Windows.
https://www.tenforums.com/tutorials/4189-turn-off-fast-startup-windows-10-a.html
10-24-2019 02:22 AM
10-24-2019 12:37 PM
muixmorbid wrote:
do you install driver from asus website?
10-24-2019 05:02 PM
10-28-2019 09:46 PM
Enderwiggin03 wrote:Microsoft fixed that issue long ago. So if you are experiencing an issue with your Realtek drivers then it is not Microsoft's fault. I have 3 z390 PCs in my house and all are working great with version 1903 installed.
It's a known Windows 1903 error, you'll net you find the affected update and uninstall it.
10-28-2019 09:43 PM
muixmorbid wrote:
Hi all, i having this issue since i build my pc. i try follow the Realtek HD Audio Drivers (UAD - ASUS ROG SS3) installation but no sound after i finish the installation. now i'm using windows update driver but videos and sound are out of sync every time i shut down the pc. I need to reinstall the audio driver using windows update every time i turn on the pc. PLEASE HELP.
Sorry for my bad English
10-19-2020 11:29 AM
