Hey everyone. It seems things have changed since my first overclock... an Intel Celeron 300 -> 450Mhz. Those were the days! My last OC was a 2500k @ 4.5 and that has been stable for the past couple of years.
Now there seems to be a lot more to it. Adaptive vs Manual, LLC, C-states enabled vs disabled. Etc. I could use some help, but I have done my research too.
First things first, I had some temp issues with XMP and MCE auto. I have a DeepCool AIO 240 and Maximus Hero X. I used Arctic Silver for the thermal paste. So, I disabled MCE and am just running XMP for the ram
@3200MHz. I figure this should allow me to get a standard temp baseline.
I'm using BOINC projects for load... as that is what this PC will be doing most of the time. Once I get to a good place, I intend to run a more standard stress test.
So my first question: With only XMP enabled, the CPU should be at stock settings, yes? With BOINC running, my temps are CPU (PECI) 85C and CPU 75C. Vcore gets to 1.37 or so. This is according to HWiNFO64.
Is 1.37Vcore what it should be stock? Am I looking at the right temps? The CPU section reports the temp at 85C as well, so I suspect the other CPU temp of 75C is something different altogether.
I appreciate your feedback!!
