My chassis fans reset to Standard curves if I lose power unexpectedly or unplug.
Squidmaster7
Hi everyone, curious if anyone else has this issue or has a resolution.
I have a Rampage X Hero (WIFI) and am on the newest bios (but this issue has persisted across at least 5 or 6 previous versions). Any time that my computer loses power (either unexpectedly or if I unplug) then my Chassis 2 and 3 fans lose their custom settings. My Chassis 1 and CPU fan do not lose their settings. I have all of the fans set with a custom curve so that they run at the same RPM regardless of temperature.
I have used AI Suite in the past but have had issues with it as well so I resorted to doing everything in the BIOS.
Is there anything I can do to troubleshoot this issue? I have tried resetting everything to no avail. IS there a more drastic step to take? For reference the fans are Noctua PWM fans used as my front intake fans.
Thanks!
0 REPLIES 0
