08-07-2018
06:19 AM
- last edited on
03-06-2024
08:17 PM
by
ROGBot
08-08-2018 07:16 AM
08-08-2018 07:30 AM
Phillyflyer wrote:
From what I'm gathering here...all you did was swap the board from one case to another and changed out the ram to Corsair vs GSkill....since then neither of the kits will report the correct voltage vs what is set in bios ...correct ??
Bios 1401 onward would have updated the ME Firmware (which is only thing that will not roll back) and should not be related the your issue....I would be more inclined to think that you may have a short somewhere on the board since it was working in a previous case without issue....Either way...the board may have to come out...test on an open bench...see if issue still exists prior to an RMA...
Just a shot in the dark here Bro !!
08-08-2018 07:36 AM
chevell65 wrote:
There were some threads where voltage sticking problems were fixed by toggling the LN2 switch on the board. Man what a pain.
08-08-2018 07:42 AM
08-08-2018 07:52 AM
Trigger5521 wrote:
OK get this snakeyes has also notice from my AIDA64 panel that the VCCSA and VCCIO voltages are out of whack
I have them set in the BIOS VCCSA to 1.25 and VCCIO to 1.2
AIDA reports VCCSA 1.027 and VCCIO 0.968
These voltages are also not responding to BIOS changes, does that indicate a short? or faulty voltage regulator?
08-08-2018 09:14 AM
08-08-2018 04:12 PM
08-08-2018 04:43 PM
08-09-2018 03:23 PM
