MCE explanations and others
Shamino
MCE
I’m seeing quite a lot of misunderstanding the workings of MCE so I’m partly writing this to address it.
It is not the taboo that it has been made up to become. There are 3 options for it, namely Auto, enabled and disabled.
Enabled merely maxes out Power and current limits so that users don’t have to manually do these themselves.
Disabled sets these limits to intel’s defaults. Even when you customize ratios, these limits are still in place unless manually adjusted.
Auto means that the board has liberty to determine what limits are reasonable, competitive, reliable and logical. Factors such as thermal, performance, Segment, competitor’s out of box perf, stability are taken into account. Logical meaning that when you customize a ratio, all limits are raised to the max with the logical assumption that you want to run that frequency and not clip from power.
Therefore it is totally redundant to disable MCE and then max out power and current limits, since enabling MCE does the exact same thing and no more. Really, just leave MCE at auto if you plan on overclocking, it does you no harm.
TVB
Now for the current emphasis on totally stock perf of the i9’s by the review sites, all the attention is on TDP but that’s just a gnat compared to the camel swallowed. NO site actually talked about and examined the latest feature of the i9, Thermal Velocity Boost TVB. By default Intel enables this but I see that only Asus boards enable this at defaults. The other boards I tested have this disabled even at defaults.
What this does is it reduces voltage guardbands depending on core temp. Traditionally, the voltage request by the proc is always based on worst case scenario TJMAX, meaning the voltage the proc thinks it needs for the frequency when temp is 100c. It is well-known that the cooler the chip runs, the lesser the voltage needed. Therefore TVB is opportunistically reducing power and temps. The behavior is quite linear and I observed the following on several samples.
TVB takes effect from 40~50x on 99k and 40 to 49x on 97k and 40 to 47x on 96k, simply 40x to single core boost ratio. The V/temp curve runs from 0c to 100c. For example 150mv delta between 100c and 0c for 50x, meaning every 1C drop from 100c VID requested will reduce by 1.5mv. The reduction is smaller as you go down to 49x, the smaller the ratio the smaller the reduction, and below 40x you get no reduction. This is good for most people running stock. You can try this yourself by noting the VID idle, and then unplug your water pump and let the core temp rise slowly, noting down the correlated temp/VID, and see what i'm talking about.
During OC, when you try to run adaptive mode voltage with this mechanism, you will need to change your perspective in how you set the ‘target adaptive voltage’ since you need to assume that’s the voltage you get when 100c and do the reduction to your lowest (usually ambient) temp and gauge what voltage is needed to be set. So if you set 1.35v for example, when you idle at 30c you will get maybe 1.25v instead. This can be confusing for many people, therefore we disable TVB once you customize a ratio. This is not to say you cannot exploit this mechanism to work for you during OC but you really need to find out your idle Vmin (lowest stable voltage). You can find this option in CPU internal power management in the bios and you can force it to enable during OC.
For those who want to check or try this on other boards, simply download r/w everything http://rweverything.com/ and add CPU MSR 0x150
Access this register and set bit 63 to 1 and [39:32] to 18h:
https://ibb.co/gUyvUf
Bit 3 shows you if TVB is enabled or disabled (0=disabled). If TVB is disabled, simply flip the bit and use command 19 to write.
https://ibb.co/jCEDFL
https://ibb.co/muKDFL
Then you can see what the default stock behavior is really like. This will truly affect temperature, power consumption, boost frequencies when TDP is default, etc so those who want to dig deeper into ‘stock performance’ really needs to get this correct.
The other thing that also affects ‘stock performance’ is the ACDC loadline programmed into the processor. Boards should let CPU know the actual loadline the board is currently set to by writing the correct loadline. This doesn’t mean that the board has to be honest about it, and with the generous guardband Intel are used to providing (not as generous any more perhaps – well you know they need to factor in stability after 10 years of heavy use for example), it is not uncommon for boards to lie to the processor so as to get it to undervolt. You cannot really tell how much the board has lied to the proc but at the same frequency/load, just by probing the inductor on different boards with a multimeter, you can see that at least more than one board is lying to the proc. Obviously TVB setting should be similar during the test or else you get very skewed results as explained above.
Finally, VRM temp should not be the only factor when evaluating a VRM, much less a whole board. For OC, my opinion is that transient response is very important. Contrary to popular belief, you do not need expensive equipment to test transient response. You can use Cache OC or AVX offset to test this.
If you played with Cache OC, you see that it is very intolerant of any undershoots. Straightaway you would hardlock or BSOD. You can even test it at default. Since it shares the same rail as core, set core ratio to something really low like 40x. Set min and max cache ratio to 43x and set a manual voltage like 1.15v. Run a heavy load like prime 95 non AVX. Dynamically slowly reduce the voltage 5mv at a time. You will find the VMIN this way. Once you find the VMIN under continuous load, stop prime95. If it doesn’t hang, run it again, back and forth between running and stopping. Even try booting straight from bios with that VMIN. You will see that this VMIN requires a guardband for transient load changes, meaning you will need 5mv+++ more. You will observe bigger guardbands needed at higher cache. Obviously the better the transient response, the guardband requirement is smaller.
There is also AVX offset, or ratio change mechanism in general that you can observe transient response. First, find the VMIN under continuous heavy load like prime95 non AVX 26.6 on say 47x cpu ratio or something with a manual mode voltage with AVX offset at 0.
Next set AVX offset to any value, such as 1 or 2. Run the same frequency/load at it’s VMIN. It will not last too long.
Avx offset or other ratio change mechanisms has always had this issue whereby voltage guardband needed is bigger
Heres why, the ratio change takes place by getting the core plls to go to sleep and then waking up to new pll frequency.
The transient is very bad and violent when u run high loads cos it will go from really high load to almost no load and back to high load very quickly.
Now you may think you did not even run AVX. For AVX offset, a lot of background stuff may run a few AVX instructions, such as dot net framework.
Sometimes u can see avx offset occur when u don’t deliberately run avx, its usually very fast and you only see the small pockets.
Therefore the ratio change occurs quickly and vmin is raised due to the guardband requirement increasing.
The way to mitigate this is to use a steep LLC and higher vid. The transient will be better.
You can trigger this guardband by doing other stuff that changes ratio, such as when running prime 95, keep setting down short duration power limit and upping it with XTU continuously.
The ratio will keep changing and finally hang when your guardband is just enough.
Or just keep changing ratio up and down.
Therefore use AVX offset bearing the extra guardband in mind. This is totally the behavior of Intel’s proc. Again, obviously you can gauge the ‘responsiveness’ of a board by measuring the GB needed. For example you can logically conclude that a board that requires 150mv GB is less ‘agile’ than a board that requires 80mv guardband.
Adaptive Voltage
Lets start from the basics, how the CPU's Dynamic Freq volt scaling works.
#1 the mobo's bios tells the processor the current loadline characteristics via AC DC loadline values.
#2 the cpu, based on its own native VF curve and the info in #1, requests for a voltage from the controller.
#3 the voltage that eventually reaches the cpu is this voltage minus the droop from loadline
easier to understand from an example:
10900k running at 4.9ghz currently and drawing 150A. bios programmed AC DC LL to 0.50MOhm.
the cpu's native vf point at 4.9ghz is 1.30v.
the cpu anticipates 75mv droop. (V=I*R,,, 150*0.5) the cpu requests for 1.30v + 75mv = 1.375v from controller.
the current VRM loadline the user sets is level 3 which is about 1.1MOhm.
the actual voltage that the cpu eventually gets after the vdroop from the mobo is 1.375v- (150*1.1)mv = 1.21v
##Note: The above is an illustration without TVB voltage optimization enabled. if it is enabled, then it adds another variable into the equation @ #2 (volt requested for -volt optimization from temperature -> we leave this as zero so that it is more understandable in the above example)
After understanding this, we can better explain Adaptive voltage, which is not too complicated but requires you to bear in mind the rules it follows.
1) When cpu frequency is smaller than or equal to the highest default boost freq, for eg 5.3 on 10900k (lets call this p0 freq):
whatever you set as an adaptive voltage is ignored by the cpu since it only references its own native vf curve at freq <=p0freq
2) And even if you are at a freq higher than p0 freq, if you set a value that is smaller than its native p0 freq vid, this gets ignored too.
example:
10900k with a native vid of 1.5v at 53x. you run synch all cores 52x and try to set 1.45v adaptive. this is futile becos cpu ignores it due to 1)
then you go up to 54x and try to set 1.475v, this is futile as well as the cpu again ignores it due to 2).
then you set voltage to 1.52v, then the cpu finally starts honoring this request because 1) and 2) are false.
=> so in short, adaptive voltage ONLY takes effect if freq >p0freq & value > native p0vid. And even so the eventual voltage you get is the result after going thru #1,#2,#3
so what to do for freq <=p0 freq, how to get volt u want in this range? well, short of offsets / vf pt offsets, you can manipulate the variables in #1 and #3 to get the v you want, ie manipulate AC DC LL values and/OR VRM Loadline values. for my preference, i would stick to a good VRM loadline that is good for transient, example Level 4, fix it in this position and trim AC DC LL values.
The svid behavior option just contains static AC DC LL presets, apart from "Trained" which is part of the AI algo, that sets a predicted AC DC LL value taking into account freq, cpu/cooler characteristics/vrm ll value.
S/w VID readings
S/w vid readings may not always reflect the actual vid requested from the controller, in fact, unless DC Loadline is written to 0.01, it wont.
what it reflects is actually the voltage cpu anticipates to get, calculated from DC LL value.
so for example, when you see VID reading of 1.35v and DC Loadline value is 0.5MOhm, what is actually requested from the controller is:
(for simplicity im gonna leave out the fixed 200mv offset requested by cpu for >=8cores)
1.35v+0.5*current at the moment:
for example:
1.35v + (0.5*180A) mv= 1.44v
So why dont we set DC LL to 0.01 and AC LL to whatever we need (since the actual vdroop compensation cpu requests for boils down to AC LL Value)?
Well you can but when AC and DC LL values differ, the current and power calculations done by the cpu gets skewed.
New VF Pt offsets on Z490:
the vf curve refers to the stock vid of the proc at various freq and the vf pt offset allows you to fine tune per each point. All these pertain to adaptive voltage mode instead of manual mode, since manual mode uses a fixed voltage setting across all freq. Bear in mind the nuance that it has to be monotonic and setting a higher freq with a lower resultant volt will only get volt as low as the point before it.
As an example, you see from bios menu or s/w that vf pt 53x is 1.334v vid
vf point 7 , the pt before that is 1.314v
say you target 1.25v VID for 53x, setting negative offset of -0.084 for vf point 8(53x) will only result in at actual 1.314v since vf point 7 is 1.314v and u cannot set pt 8 lower than pt 7. at this time, you then decide to set vf pt 7 to negative -0.069‬, and this sets vf pt 7 down and also allows vf pt 8 to come down to 1.25v.
the software tool i posted forces you to adhere to this rule so its useful for runtime testing in os and allows you to free yourself from doing the math.
this is to illustrate the rule it adheres to, but an illogical approach because i dont think one should target a voltage for a freq but target a freq and get the necessary volt for it.
so in actual use case, you would just be trimming and trimming each point, double checking stability throughout the trimming process.
Edit: 11/19
Update of new Feature: Overclocking TVB:
OverClocking TVB is an extension of the TVB feature allowing you to customize frequencies according to temperature.
This, in my opinion, is a useful feature that milks the last bit you have got at light loads without requiring additional voltage. In a nutshell, it takes that 5~8C extra margin you’ve got, and converts it into additional frequency.
It is only supported on 10900K/non K variants atm, and maybe 10850K. IF unsupported, the information will display N/A
Everything TVB related is now grouped into the Thermal Velocity Boost menu:
86774
86775
At the top, it reads back the current configuration of the OCTVB.
For this to work properly, CStates must be enabled for proc to be active core aware! If you synch all cores, make sure you manually enable Cstates.
Active Cores refer to the row of settings applicable when that number of cores are active. Ratio Setting refers to the associated core ratio for that active core count. Temp A refers to Temperature A for that active core count above which the ratio would drop by it’s associated Ratio offset. This offset is the Negative Ratio Offset A pictured above. Temp B refers to Temperature B for that active core count above which the ratio would drop by a further 1x.
Let’s take a simple example below:
86777
Right now Cpu runs at 50C and only core is currently active. Ratio is therefore 55x.
User does something, the active core gets hotter and becomes 72C, and still only 1 core active. Ratio now becomes 55-1=54x because 72c is > Temp A 68C and the negative offet is 1. If negative offset is 2 for eg, then it will become 55-2=53x.
And then, the user loads it further and now temperature is 82C. Ratio now is 55-1(from TempA) -1(from TempB) =53x because temp is > tempB of 78C and a further 1x is deducted. Temp B negative offset cannot be configured and is a fixed 1x.
Then the user does something different and now 3 cores are active. The applicable row becomes the third row in the picture above. CPU runs at 60C right now and so none of TempA/B has been exceeded, therefore ratio is the original 53x. then proc gets to 77C, TempA is breached, it’s associated offset is 3x so proc drops to 50X. Again it runs hotter still, gets to 87C. TempB is breached, proc drops a further 1x and ratio is now 49x. And the story continues…
Hopefully, this example is enough to explain.
86776
The control is under Overclocking TVB, customize it using “Enabled”
When enabled, you get to customize the params for each row (each active core count) The Ratio, you configure it the main menu like you always do, whether you go with synch all cores (if you go with synch all cores pls manually enable cstates so that the proc can tell number of active cores) or by core usage it doesn’t affect this.
86778
It can be very time consuming to customize it yourself, so we have made 2 predicted presets for you, the +1boost profile and +2boost profile
86779
Just use it ON TOP of your current/maximized oc setting.
It will do an additional 1x/2x on top of your current setting and set auto-calculated temperature boundaries based on the associated frequency. This does not add voltage because it still uses the voltage before adding the boost and merely tries to scrap some performance from moments when there is thermal headroom.
So for example, I would load Ai optimized, then enable to +1boost. I find it stable, feel a bit adventurous, then I change it to +2boost and try.
Or my current OC is 54X @ 1.4v, I keep this and I just go into OCTVB to enable +1 boost. (if you go with synch all cores pls manually enable cstates so that the proc can tell number of active cores, or just use by core usage and set every core count to same value)
OCTVB for RKL is slightly different:
Guide:
https://www.dropbox.com/scl/fi/hz7laveryk4bbwo645a54/rkl_octvb.docx?dl=0&rlkey=f55vy6z360xcmorii2xv3...
86780
Flow Chart to visualize the decision-making process of the processor for Voltage and Frequency. Obviously the evaluation is continuously looping and the V and F flows are intertwined, ie you can imagine the Frequency flow continues into the voltage flow. Not exactly so, but close enough for comprehension.
26 REPLIES 26
Luck100 wrote:
I have the Asus version of Intel XTU that comes with the Maximus XI Hero.
Well, I guess just use Intel's own version then.
Luck100 wrote:
Yes, this is how all the dynamic clocks work. At any given instant in time, all the cores must run at the same multiplier. It can sometimes look otherwise in HWinfo, but that's because it's not actually measuring all the core multipliers at the same instant of time.
Ahh ok, thanks, forgot about that.
What exact settings are you running on the Hero to achieve the balance of AVX/non-AVX?
Not sure what you mean by balance of AVX/non-AVX. These are the setting which I've changed from default values:
Ai Overclock Tuner [XMP I]
XMP [XMP DDR4-3200 16-18-18-36-1.35V]
BCLK Frequency [100.0000]
ASUS MultiCore Enhancement [Disabled]
AVX Instruction Core Ratio Negative Offset [0]
CPU Core Ratio [Sync All Cores]
1-Core Ratio Limit [49]
DRAM CAS# Latency [16]
DRAM RAS# to CAS# Delay [18]
DRAM RAS# ACT Time [36]
CPU Load-line Calibration [Level 6]
Long Duration Package Power Limit [180]
Package Power Time Window [5]
Short Duration Package Power Limit [225]
CPU Core/Cache Current Limit Max. [255.75]
CPU Core/Cache Voltage [Offset Mode]
- Offset Mode Sign [+]
- CPU Core Voltage Offset [0.035]
DRAM Voltage [1.3500]
CPU VCCIO Voltage [1.15000]
CPU System Agent Voltage [1.10000]
Ok, short follow-up, I've tested power limiting AVX/FMA3 load a bit. I see 2 problems with it:
1. The transition from the high multiplier towards the lower, power-throttled one is still occuring (well, of course, what was I thinking?;)). It might still be triggering the transient crash and nothing's really gained.
2. The limited frequency probably is whithin "normal" operating range (36x - 49x for my 9700k), applying adaptive voltage VIDs as it's supposed to. But this might not be enough for the torturing AVX load, leading again to a crash. Way out is applying a positive offset voltage, but then, this means higher voltages overall.
So... I don't really know. Might be that in the end we actually end out roughly in the same voltage regions as when using AVX offset in the first place. Nevertheless, just for "safety" reasons it might be a good idea to limit power consumption anyway.
Oh, and why actually use PL1/PL2? Limiting IccMax achieves the same goal and is much simpler to test/stabilize, or am I missing something?
I'm not using power limiting for stability. My chosen voltage/clock is stable. But I'll hit 100C if I run a heavy AVX load for very long. The power limiting just knocks the clock/voltage down gracefully for those cases so I don't go bouncing off the 100C thermal limit (which will cause a much bigger downclock anyway, aside from any concerns about being too hot). I think this is better than an AVX offset because I can still run light AVX loads like BF5 without any downclocking at all (because they don't draw too much power). Bottom line, this won't help if you're not AVX stable already.
I suppose I could use IccMax instead, but I never tried it. There's nothing complicated about setting PL1/PL2 and you can allow a higher short-term power burst with PL2.
Ahh ok sorry, I might have misunderstood you then. My goal was to exploit power-limiting for stabilizing AVX offset transitions - or really any kind of clock transitions - in some way, and in that sense, I think it doesn't really work. For generally keeping temperatures in check, sure.
That said, I wonder how you can really be sure your "chosen voltage/clock" is truly stable if you cannot run prolonged, full AVX-load because of temps?
EDIT: I guess forget that question. You're simply stable, enough vcore applied, but you would just need better cooling. All clear. 🙂
Anyway, after testing some more, I actually do think limiting power is a good idea and the better/easier route compared to using AVX-offset. It might not be 100% Prime-stable in the end, but in practice this doesn't matter, at least in my use cases. Failing Prime still is far better than a random BSOD, which is prone to happen when using AVX-offset with vcore too low...
Hmm, not much interest in this thread it seems, yet this is a very essential topic for CPU overclocking imo, esp. the AVX-offset thing.
Some more testing on my part shows that XI Gene performs similar in this respect. Guardband appears to be even larger than on the Z390-F, but it's not directly comparable because the Gene has 8 LLC levels (use 6 or 5). Overall Gene is better, that's for sure, albeit not by that much, at least for normal, non-subambient operation.
One last recommendation in general: Don't use AVX-Offset! It's only leading to instabilities, requiring more vcore in the end than with limitng IccMax instead. The trick with IccMax is to apply positive offset voltage when using adaptive voltage, that's all. Without that it will crash because of the too low AVX-voltage on lower multipliers. For fixed voltage I don't know and I wouldn't suggest to use that anyway. Think of power usage and I've yet to see cases where higher 24/7 overclocks have been achieved using fixed voltage in contrast to to adaptive voltage, this is a myth imo. Adaptive Voltage is the way to go since Skylake. Fixed is easier to stabilize, yes, but it's not the correct route for a 24/7 overclock.
Stu
Wow, the standard of knowledge around here has improved somewhat since I left all those years ago!
Great topic guys, I am looking forward to learning from you. 🙂
Asus Maximus IV Extreme Z
i7 3770K @ 4.4ghz
AMD 7970 HD x3 in TriFire @ 1200/1800.
2x 240GHZ OCZ Vertex 3 SSD & 1x 512Gb Vertex 4
16GB 2133mhz Patriot DDR3
Ennermax Max Revo 1500w PSU
Huge water loop with an internal EK 340mm & external Supernova 1260mm
Windows 7 64 bit.
Aquaero Fan control & monitoring
My CPU is running 5.6GHz with a 280mm AIO.
Motherboard: ASUS Maximus XII Formula - BIOS 2103 - SVID@Trained (AC/DC loadline: 0.510/1.100mOhm) - LLC#4@900KHz - Adaptive@1.524V - VCCSA@1.240v - VCCIO@1.190v
CPU: Intel Core i9-10900KF SP86 => 56x4 - 55x6 - 54x8 - 53x10 <= (+2Boost OCTVB profile, VMaxStress, VoltageOptimization) - Ring@8~47x -
Full Load: 51x@1.240v
V/F Offsets: VF#1@659-8mv / VF#2@794-3mv / VF#3@914-3mv / VF#4@1054-3mv / VF#5@1169-18mv / VF#6@1328-12mv / VF#7@1328+53mv / VF#8@1428+95mv
Well, congrats on this chip, seems to oc very well, but also very high vcore, no?
I wouldn't recommend running that 24/7, far too high. Remember, Maximus boards are about correct on voltage, in contrast to the lower tier boards where you can substract at least ~100mV from the HWInfo reading under full load. Real 1.47V is far too high and I doubt you can keep temps in check with an AIO. Show screenshot under full, prolonged Prime95 small-FFT non-AVX load, that's when we're talking! 😉
R23 - Full Load: 51x@1.240v
Light loads: 56x4 - 55x6 - 54x8 - 53x10
I don't think I can maintain full load for hours... But I can play BFV all the night 🙂
