Maximus XI extreme realtek sound issues after driver update
br007
Hi all, hope I can get some help. Built new PC 4 months ago and had no problems. Last week ezupdater stated that there were updates to the driver. Ran update then all sound ceased to work. Went to support audio drivers and ran assetup in zip file. still no resolve. To get the sound again I had to remove realtek app, sonic studio, sonic radar and all the drivers. Rebooted and the system loaded the microsoft drivers. Now the sound works. I realy would like to use studio and radar but after they load sound stops again. Thanks for your help!
5 REPLIES 5
MoKiChU
Level 40
Try with Realtek Audio Drivers (UAD - ASUS ROG/PRIME/TUF MB) from my UAD drivers thread.
Follow scrupulously your INSTALL process with cleanup step, for the next drivers packages that I would release, you will can directly follow the UPDATE process.
Note (in order to choose correctly the install/update process to use) : You have a ASUS ROG SS3 motherboard.
Thank you, will i be able to use sonic sound then? Are you a developer?
Yes, of course.
No.
Asus technical support says my 4 month old board is bad???
How can that be when I can run the audio with windows drivers?
Before talking about RMA, did you try what I told you in my previous post ?
