Maximus XI Extreme MonoBlock?
btrach144
Can anyone from ASUS say if they are working with EKWB or Bitspower on a monoblock for the XI Extreme?
Ideally I would want one of Bitspower's 'smart' monoblocks that can use the onboard monoblock header.
16 REPLIES 16
S3RIOU5
how sad is it, that ASUS *don‘t answer to this problem 😡 !!!!!
S3RIOU5 wrote:
how sad is it, that ASUS *don‘t answer to this problem �� !!!!!
Hi, there isn't a problem to answer as far as I can discern. We have implemented the means for other vendors to utilise the header if their products allow.
Last time I checked, EK representative has said there will be a header included, however, you would need to clarify with the company that is making the product...
? we have now almost march, *and nowhere a mono block with the integrated sensors .*
The connector is optional for the WB vendors to use. Whether or not they do is up to them. The function is there if they want it. If you have issues with them not using it, you'll need to contact them. Bringing it up here is not going to help your cause.
Doza18
I'm interested in the maximus xi extreme, and I like many others would like the option to watercooler the CPU and vrms with a monoblock. I see that bispower has one in their own website, I don't see it in the usual places where I buy my water cooling products, as of yet. I do have a simple question regarding the installation of a monoblock. that is if it requires the removal of the I/O cover? In other words is the VR heatsinks and the I/O cover one piece?
The IO shield is separate from the vrm heatsinks
Asus ROG Maximus XI EXTREME
Intel i7 9900K OC'D @ 5.2 GHZ @ 1.345V (1.296V LOAD) LLC 6 PRIME 95 STABLE 8 HRS
XSPC RX360 Rad (6)Scythe Gentle Typhoon 1850 RPM Fans In Push/Pull @ 1500 RPMS
Swiftech Drive II / Swiftech MCP35X Pump
Enermax Platimax 1200 Watt Power Supply
32GB G.Skill F4-3866C18Q-32GTZR 3866 MHZ CL18 1.35V (OC 4266MHZ 17-18-18-41-2T @1.45V)
MSI GTX 1070 SEA HAWK EK X SLI WITH ASUS HB RGB
(5)Samsung 840 Pro 128 GB In Raid 0
(2) WD 1TB Black Edition
Corsair 900 D
Doza18
Thanks for the info. Yeah it's weird in the bitspower website, the product photos shows the installed monoblock with a bare I/O.
https://shop.bitspower.com/index.php?route=product/product&path=67_97_354&product_id=7126
