12-18-2020
06:21 AM
- last edited on
03-05-2024
07:26 PM
by
ROGBot
12-19-2020 01:43 AM
12-24-2020 06:38 AM
12-26-2020 01:44 PM
12-26-2020 11:03 PM
12-27-2020 12:32 PM
Jesseinsf wrote:
It sounds like you want to achieve the same results after installing the new BIOS. Your issue is not necessarily a Bug (It could be). All I know is when I see "Stability improvements" in the Fixes I then have to accept the fact that I may have to start setting up a new OC from scratch. Meaning the previous settings may not work anymore so I have to go through the whole OC process again to achieve then same or (Hopefully) better results.
12-27-2020 02:27 PM
Re@per wrote:
you post the same answer in every thread.... you see how many people have problems with the bios 1802... if you have no problems then post your specs and settings... your answers don’t help anyone...I’m not a newbi neither a pro but. If I use the standard settings before and now with the same settings I have problems with the bios 1802 there must be something wrong now... or they make this on purpose for selling new products... btw they didn’t post a change log...
12-27-2020 12:36 PM
Loadlineac wrote:
Hi there,
I've had problems with the board since 1802 that weren't there in 1704. The following: It comes after the PC was without power, I get "6A Detect Memory" and then the PC hangs. If the PC was not without power, everything works perfectly. I set everything back to the way it was in the BIOS!
What's going on there?
Does anyone have the same problems?
12-28-2020 06:53 AM
12-28-2020 06:13 PM
Carlyle2020 wrote:
Works wonders for me:
How about you help US help YOU by posting your hardware and your Bios settings please?
This is not an issue concerning all users, so kindly provide the standard details before asking for proper help.
