Long Duration Package Power Limit is safe? Or keep FULL PERFORMANCE in Windows?
lpiotrowski211
Hi.
My mobo Asus Prime Z390-A, and 9900K.
3dmark graphic test 2 was throttling my cpu speed. I made a HIGH PERFORMANCE from BALANCED plan in windows settins and fps are normal and no drops and full boost. Any ideas? So keep high performance plan in Windows?
Or just Long Duration Package Power Limit change in uefi from 95W to 155W? What is better?
ps:
MultiCoreEnhacement is OFF in UEFI. AUTO is bugged.
So actually yes. MCE is OFF,Power PLan on HIGH PERFORMANCE and 4,7ghz is always on stress. All other default in UEFI.
15 REPLIES 15
Guitarmageddon1
lpiotrowski211 wrote:
Hi.
ps:
What I have done on the 8709k and I believe you need to do as well is just max out the short and long duration limits. I think you can just type a huge number in there and it finds the max it allows. Can't remember what it was. That should fix it
lpiotrowski211
Also high performance is ok too?:)
x-rated
high performance power plan in windows is good for benchmarking only, no need to maxing out everything while browsing websites 🙂
lpiotrowski211
I enter: SHORT DURATION POWER LIMIT : 155, LONG DURATION POWER LIMIT: 155 and nothing helped. On low res cpu is not raising fps. There is only Package Power Time Window on AUTO. So what i must to enter?
JustinThyme
155 is a very low number. To max it out type in 4095. Only do so if you have active VRM cooling though.
Its not a percentage.
Like XRated said performanace power plan is only good for benches. Ater return to balanced or a modified balanced. I modify the balanced to suit my needs like monitor sleep to never no hibernate, no sleep, no turn off drives etc as when Im done with my rig, I shut it down.
This reduces heat and wear on components.
lpiotrowski211
SHORT DURATION POWER LIMIT : 155, LONG DURATION POWER LIMIT: 155 Package Power Time Window on 155 too? Or left auto?
lpiotrowski211
Hi.
My cpu 9900K and mobo Asus Z390-A
What i must to enter here:
According to :
https://forums.intel.com/s/question/0D50P00004AV6GGSA1/how-can-i-set-up-a-95w-tdp-limit-for-my-cpu-i...
I already solved it, I write the soultion here just in case someone else has the same problem: I used the PL1=95W, Tau: 10s, PL2=120W they used in the techspot article I linked. With my Asus BIOS PL1 is called "Package Power TIme Window", Tau is called "Long Duration Package Power Limit" and PL2 is called "Short Duration Package Power Limit". Temps are between 70-75C in CPU heavy titles like Battlefield V, while turbo boost is working as intended.
So to LONG DURATION 10 enter ?!
lpiotrowski211
bump
lpiotrowski211
Cinebench first run is always 2050 points, then next 1940 and third 1850. Then i wait some minute run again and is 2050 points agian. Its not temps issu.
But.
i enabled MCE and scores are 2150 consistent
kepping MCE ON when my scores are higher and not fluctuating its not bad etc?
